leadfootmelvin
Jun 9 2008, 08:45 PM
i may soon need new boots on the front. but, i've read that you need to deactivate air suspension via a switch in the tool box hole, well, i can't find such a switch on my 2001 ls430. if they jack up my ls430 to swap the dunlops will this jigger my air suspension?
thanks, leadfoot
Scorps01
Jun 9 2008, 08:52 PM
B4 jacking up any vehicle with A/S you should turn off the function so as not to damage it, best check h/book.
jsj24uk
Jun 9 2008, 09:23 PM
When I had my back ones replaced, they just jacked the back end up on two trolley jack. Doesn't seem to have caused any problems. Apart from a bill for nearly £400.00
Matrixabc
Jun 10 2008, 12:21 PM
I have just had the front and back tyres changed , they jacked up the front, and the rear on the second visit with no problems, I would have thought if the ignition was off then the air compressor would not function?unless it a air tank?
leadfootmelvin
Jun 17 2008, 11:12 PM
yep, read the manual now.
if ignition is off, you can safely jack it up.
345p manual is quite a read.
click here.
