Full Version: Suspension Replacement
Lexus Owners Club > Lexus Models > Lexus IS200 / Lexus IS300 / SPORTCROSS > Brakes & Suspension
LexusIRE
Alrite was looking through the 'DIY' suspension replacing and was just wondering about the baljoiont on the front. When they are separted can you use the same nut and bolt or do they need replacing or what is needed. Opinions please
thanks Chris
wheels-inmotion.co.uk
QUOTE(LexusIRE @ Jun 19 2008, 07:04 PM) *
thanks Chris
You don't need to undo the ball-joint nylock nut.... It's best to remove the two bolts that hold the ball-joint to the wishbone.
Monster Mat did a pictorial on how to install.... It's in the clubs knowledge base.
You can use the same one mate AFAIK.
LexusIRE
Alrite sound lads. Will do that. Thanks
