Full Version: Tools For Brake Disc And Pad Change.
Lexus Owners Club > Lexus Models > Lexus IS200 / Lexus IS300 / SPORTCROSS > Brakes & Suspension
Gareth Rose
Hi guys,
Im changing my front discs and pads tomorrow evening, and was meant to be reading my newly bought .pdf manual to make sure I had all the tools ready.....but I left if it still in its envelope in work. So.. what do I need. Anything special? Or just general stuff. Ive got copper slip, and Il had some wet and dry to clean the sliders. Anything else.
Cheers guys
Gazza
QUOTE(Gareth Rose @ Jun 24 2008, 06:56 PM) *
Hi guys,
Cheers guys
Gazza
No special tool needed, not to sure on the size of nuts, but 15mm or 17mm or 19mm to take the caliper off. and some big grips to push the caliper piston back in (using bit of wood or rubber so you dont damage the piston)
Hi Gazza,
check this thread.
It shows all the info you need (GS300, IS200 & IS300 share brakes)
regards
Wozza
Gareth Rose
Cheers guys, thanks for the fast replies,
I think il be printing the guide and using it tomorrow.
Thanks again
Gazza
