QUOTE(DJ Wozza @ Jun 27 2008, 03:08 PM)
QUOTE(Rob's Lexx @ Jun 27 2008, 02:48 PM)
aye, but the boost one is a PITA IIRC ??
shall have a think
and whilst you're at it, get a School Science Teacher to explain the abreviation for us
I was thinking i was something to do with PSI
BOOST ETC
All you will need extra is plastic 'T' bit to join the vac pipe for the boost gauge, you connect wire to live/light wire in your dash for the lights to come on when you put your lights on
hard bit might be getting the rubber tube through the dash to connect with vac bit.
Oil temp, same wiring, but sensor is in the sump plug, so from dash to sump plug, you dont need to drill the sump plug as i have that bit to, as i say the only bit you will need is the small plastic ''T'' bit for the boost
