sexohgodyezz
July 8, 2008, 6:16 am
My Toyota Soarer/Lexus SC400 airconditioning won't blow warm air. It still works for cold settings, but when I turn the temp. up, there is no heat at all!
WHy is this????
ANyone else had this problem.?
How can it be fixed?
aaronabbott
July 8, 2008, 6:55 am
sounds like the heater matrix has gone
sexohgodyezz
July 8, 2008, 7:03 am
[quote name='aaronabbott' post='560468' date='Jul 8 2008, 04:55 PM']sounds like the heater matrix has gone[/quote]
thanks. What is it and where is it?
aaronabbott
July 8, 2008, 7:10 am
its basicly a radiator and id imagine its under the dashboard but not sure where abouts its usually in the middle somewhere
Rob
July 8, 2008, 8:43 am
do you get heat with the airconditioning off??
Geoffers
The heater matrix is very big job to change usually and wouldn't look towards that yet.
Maybe it could be the solenoid on the heater control valve but don't know your car so couldn't tell you where it is I'm afraid.
Also, there is a 'flap' (blend door or damper) that moves across between ducts for hot or cold. I don't know where yours is but you can usually manually moves these over from under the dash. It will be around the heater box / hvac somewhere. If it is this, it could be the flap sticky or not getting control power.
Have you done anything with your coolant? It could be an air bubble if you've drained or let it get very low.
sexohgodyezz
July 9, 2008, 7:53 am
[quote name='Rob' post='560499' date='Jul 8 2008, 06:43 PM']do you get heat with the airconditioning off??[/quote]
thanks. Hope its not expensive...
Yeah I have tried all the settings..and the heating does not work with any (even with aircon. off and only fan on).
E910
August 16, 2009, 10:25 am
Sound like it could be the heater tap/valve thats stuffed. It's a common fault on EF-AU Falcons also
[url="http://www.toyodiy.com/parts/p_J_1997_TOYOTA_SOARER_UZZ31-ACPZK_8716.html"]http://www.toyodiy.com/parts/p_J_1997_TOYO...ACPZK_8716.html[/url]
click here.
