Full Version: Will 17 X 8 With 40mm Offset Fit?
Lexus Owners Club > General Lexus Forums > Wheels & Tyres
javadude
My wife has agreed to me getting some new bigger (17") alloys :D but the ones I'd decided on (with some help from you guys) are League Tantrums. I've just found out that the nearest fitment they do is 17 x 8 with a 40 mm offset. The standard 17" wheel fitment for an IS is 17 x 7 with 45 mm offset. :blink: :sad:
Will the 5 mm offset difference be a problem?
When combined with the extra width (8") will I get any rubbing etc?
wildrnes
[quote]When combined with the extra width (8") will I get any rubbing etc?[/quote]
only if you play your cards right
:yahoo:
Chris.S
[quote name='wildrnes' date='Apr 10 2003, 10:23 AM'][quote]When combined with the extra width (8") will I get any rubbing etc?[/quote]
:yahoo:[/quote]
[i]You stupid boy [/i] :lol:
javadude
:blink: :blush:
javadude
Hmmmm I've decided I'd be happier with an exact match to the spec of the standard 17" wheels even if they would be ok-ish.
So I've gone for a different wheel. It took a while to find something suitable - eg exact spec, that I like and most importantly pretty cheap!
NigeSt
[quote name='javadude' date='Apr 10 2003, 03:50 PM']Hmmmm I've decided I'd be happier with an exact match to the spec of the standard 17" wheels even if they would be ok-ish.
So I've gone for a different wheel. It took a while to find something suitable - eg exact spec, that I like and most importantly pretty cheap![/quote]
Hi Javadude,
The OZ Hydra's I'm looking at have a 48mm offset (45mm being the IS standard), but I don't know how significant that is. What did you learn about the sensitivity of the offset value?
Also, what wheels did you choose instead? :)
Thanks,
Nige
Bazza-old
35mm will rub rear wheel arch
40mm will fit
45mm will fit
with standard ride height
all with 8" width
NigeSt
[quote name='bazza' date='Apr 10 2003, 05:06 PM']35mm will rub rear wheel arch
40mm will fit
45mm will fit
all with 8" width[/quote]
..so would 48mm offset (without problems :) )
Thanks,
Nige
javadude
[quote]35mm will rub rear wheel arch
40mm will fit
45mm will fit
Thanks Bazza. I found somewhere that could supply Kosei Sniper wheels though which were my first choice a while back. Found they are an exact match for the spec of the standard 17 wheels, look cool and are a reasonable price...
[img]http://www.mycgiserver.com/~cjlack/kosei-sniper.jpg[/img]
Fever
Nice choice Javadudewill look sweet.......
.....by the way, if you are still in deciding mode, be carefull of League alloys...especially the Hyper Black finish....they have had to recall a load of stock, the finish has been flaking off the wheels in their range. They are not fantastic quality!!
Defo stick with the Kosei's!!!! B)
javadude
[quote]Nice choice Javadudewill look sweet[/quote]
Thanks. Here they are fitted to a honda (also in 17" size)...
[img]http://www.purehonda.com/intweek/39a.jpg[/img]
Tommo
Look good, will show off those painted calipers too. Post some pics if you decide to get them, think they would look great on an IS B)
Bazza-old
[quote]Thanks Bazza. I found somewhere that could supply Kosei Sniper wheels though which were my first choice a while back. Found they are an exact match for the spec of the standard 17 wheels, look cool and are a reasonable price...[/quote]
they look gorgeous
go for it
