A friend of mine bought a GS300 (about a week after he saw my LS400
- Alternator not charging (red battery in rev counter/speedo (I forget which))
- Low oil level light (the amber one, not low oil pressure)
- Brake system fault (red brake drum symbol with ex. point in it)
- Low washer fluid
- Faulty bulb
Switching the ignition off/on did not clear the lamps. Also, when switching on, not all of the lamps lit (only the ones described, plus the "check engine" and "oil pressure" warnings - both of which extinguished when the engine was started).
Oil level is fine BTW, we checked that.
SO - crashed ECU? Or something more serious?
Any thoughts/ideas most gratefully received.
Cheers,
Ade.
