hey guys im new into the lex scene, luking 2 buy a is200 hopefully soon, dont want to spend over £3500 really, if anyone can help plz feel free, thanks.
P.S. if i was to buy a is200 what kind of millage should i go for, thanks.
Jul 29 2008, 02:01 PM
Welcome to LOC & good luck with your search
The mileage is not a factor so long as it has been serviced regularly/looked after. Check inner front tyres for wear, and ball joints for any play/noise. Check if timing belt has been replaced as this is a must for a higher mileage car (60,000+). Check water pump for signs of leaks (left side of engine as you look from the front)
kam05
Jul 29 2008, 02:03 PM
With a budget of £3.5k you are probably looking at 1999/2000 registered cars with 100k+ miles on the clock. Don't be concerned with the mileage too much, Toyota/Lexus cars can take the high mileage as long as they have been serviced regularly. Look for service history, (not just stamps, but invoices- main dealer/indy).
Also make sure the timing belt (with Idler and Tenisioner) has been replaced (look for proof, ie: reciepts). The timing belt should be changed at 60k or every 5 years, whichever comes first. Not much goes wrong on the IS- look for leaking waterpumps, knocking balljoints, corroding alloys and jammed CD players. Also check for inside tyre wear on the front, if the tyres on the inside are bald but the rest of the tyre has a decent amount of grip this indicates a problem with a car geometry (wheel alignment). A trip to Wheels-In-Motion (Tony Bones) will fix this.
Welcome to LOC btw.
Lexus2D
Jul 30 2008, 08:30 AM
Hi & Welcome 2 LOC
spikes
Jul 30 2008, 06:05 PM
hi,welcome to loc
treborlex
Jul 30 2008, 06:14 PM
Hello & welcome to the loc.
tridentmorph
Jul 30 2008, 07:37 PM
Greetings and good luck with your hunt.
aztecbandit1
Aug 2 2008, 08:58 PM
Welcome to the club matey and good luck with your search
iceman67
Aug 2 2008, 11:11 PM
hi and welcome to the loc
