Full Version: Another New Tyre Thread
Lexus Owners Club > Lexus Models > Lexus IS 250 / Lexus IS 220D / Lexus IS 250C
Infinity
I've tried this earlier on another post with no response so i thouht it give its own topic sorry for the repetition.
I'm trying to find 4 new boots for my 250SEL and struggling
The originals have done 30k and are being replaced, as the dealer is changing the
wheels due to corrosion. The originals are Bridgestone Potenza 225/45R17 and 245/45R17
the original pattern is an RE050 but the rears it cant get anywhere so i have been
offered the the same Bridgestones as asymetrical RE050A does this make any difference?
The RE050A's seem alot cheaper, or am i just worrying over nothing.
Infinity
bridgerippa
the difference is when the tyres are fitted. asymetrical tyres can run properly clockwise or anticlockwise. when you look at the tyres fitted to the right and left wheels they tread patterns will not be symetrical
a rough look would be asymetrical= <(( left tyre <(( right tyre
normal symetrical tyre= <)) left tyre ((> right tyre
so re050's can only be mounted on the rim one way and will be marked inner and outer. re050A's will not be marked inner and outer so can be mounted either to run clockwise or anticlockwise.
asymetrical tyres always look a bit odd to me as if theyve been fitted wrong but the advantage is they can then be mounted on any corner of a car.
dave1
QUOTE(bridgerippa @ Jul 29 2008, 09:34 PM) *
I was told by several tyre fitting places that asymetrical and "normal" tyres should not ideally be fitted to the same axle.
dave1
Asymetric tyres WILL be marked inner and outer and as such can only be fitted to the rim in one way. They have a different tread pattern on the inside to the pattern on the outside.
bridgerippa
QUOTE(dave1 @ Jul 30 2008, 08:59 AM) *
eXOBeX
Exactly what I was thinking. Symmetrical tyres will have a direction-of-rotation arrow instead.
markoose
My IS220d was supplied from a Lexus dealer with one asymmetric Dunlop and three symmetric Bridgestones. I almost came off the road more times than I can remember, the steering was feedback free and scarily light; I just thought the car had crap handling. I fitted four Continentals and it is much more responsive although why did Lexus fit such a quick steering rack to a car with such poor handling? It just means you can upset the chassis quicker.
dave1
QUOTE(markoose @ Aug 7 2008, 01:50 PM) *
I assume that it was a Lexus Approved Used. Did you not notice during test drive or when inspecting the car prior to deciding that you were interested in purchasing it?
Prior to purchasing my 430 I saw that the rear o/s was asymetric....the other 3 were normal. As the fronts on my 300 trade-in were the same size and with more tread I got them to swap them from my old car to the "new" one.
Paradroid
@markoose - I thought the new IS was supposed to have great handling. Does it not? What are you comparing it to?
@dave1 - he probably didn't get the chance to push it on the test drive smile.gif I got caught out with this a bit too. When I test drove my IS200 I thought it felt very sporting, but that was driving at normal speeds. The suspension seemed very good and the steering felt sharp. When I pushed it hard on a back road at the weekend I wasn't too impressed. Things might improve when I get new tyres all round on Saturday...
