I just came across a guy selling his charger and all the bits with it off his car.
He is selling,
TTE Supercharger (covered roughly 8k miles)
ECU extension (black box)
Kazama back box
De-cated manifold with modified heat shield
Denso spark plugs
Hks blow off valve
Blue silicon hoses
Clutch relocation kit
Intercooler and all Brackets (bits and bobs)
Full fitting instructions.
So i was wondering a few things before i buy the kit,
1, What to look out for in regards to problems with the compressor unit?
2, What sort of problems might i have with the ECU extension black box, as ive read some have gone wrong?
And what might be a good substitute or upgrade.
3, Will my car need to be re-mapped when the kit is fitted?
4, Is there anything worth buying / upgrading before i fit it on the car? (pulleys or belts ect??)
5, Instead of using the Clutch relocation kit which i believe you have to tap into a brake line to use and remove the clutch master cylinder due to the airbox, is it better to get an induction kit?
6, Anyone know any places local to the Essex area that will fit it? (im in colchester but will travel)
Or anyone willing to help me fit it as im not all that mechanically inclined? will pay
Cheers for any help
Tom.
