No Probs, Guys,
Sorry fo the delay..
Some of you will have received 2 x Bulbs and some of you 4 x bulbs.
For those that received 2 x bulbs, it's up to you to decide whether to put them in your dips or full beam.
If you put them in your dips, then you'll get the benefit of them all the time.
If you put them in the full beams, then obviously you'll only benefit when you use your full beams.
Do also be aware that the colour temperature of your new PIAA's will be diferent than the standard bulbs.
PIAA Xtreme whites are not only brighter, but look whiter too.
Just to fill you in, you have received the H217 bulbs. These can replace 9005/9006 HB 3/4.
So don't worry that they appear to be 2 x dips sets@ at 55w
They'll work equally well in both dip & full beam. (And keep you closer to the right side of the law.)
Enjoy those compliments your going to get...
