Typhoon
Aug 3 2008, 03:04 PM
Hello all
Just recently took delivery of a 2008 RX400h. It is a very good car but for some reason, I find the drivers seat to be uncomfortable -- after spending 25 minutes in the vehicle, I start to develop a pain immediately below the bottom of the back of my neck.
It is a very strange problem as my back is fine -- I drive other vehicles and find no such problem. On examining the drivers seat, I have noticed that the seat is very flat immediately above the lumbar support area -- there is no real padding as such either and I find this unusual -- most seats do have some kind of support in this area or at least slight padding.
Just wondered if any other RX drivers find this problem ? It would help if someone roughly my height (6ft) could provide an answer (as this would obviously have an effect on seating position)
Many thanks
ETA: I have played around with the seat position a great deal and still no luck.
jamesholden
Aug 3 2008, 05:41 PM
If it's hurting you around or just beneath your neck it is unlikely to be your seat but the way you are sitting relative to the steering wheel and pedals. It means your sitting slightly twisted or straining slightly when holding the wheel rather than sitting perfectly square, try adjusting the reach on the steering wheel.
airwaves
Aug 5 2008, 06:01 AM
adjusting your seat properly may solve your problem; many people actually don't know how to do this. Use this
tutorial.
_________________________
Autopartswarehouse
Rillo
Aug 5 2008, 10:56 AM
In my experience Lexus seats are the weak part of the experience for some. I found that the padding /support went in my seat base after about 12000 miles. I spoke to Lexus about it and they replaced the seat for me.
In fact I have had seats replaced in LS, GS and RX!!! Maybe I have a wonky bum?!!
lfoggy
Aug 6 2008, 06:58 PM
On my RX400h an annoying fold of leather developed on the seat base that did become uncomfortable for me. Lexus replaced this and I now find the seats fine.
Your problem sounds like a case of experimenting with the seat position rather than a problem with the seat itself. Don't forget to experiment with the lumbar support which will alter the curve of your back and which may improve things for you.
Typhoon
Aug 8 2008, 10:14 AM
Thanks for the replies. Adjusting the reach of the steering wheel did the trick !
Cheers
holeinonep
Sep 7 2008, 11:43 PM
Hi Typhoon,
having the same problem. did you adjust your wheel in or out? Also where do you have your wheel on the up and down adjustment. Thanks in advance for your help and this is very frustrating.
click here.
