Full Version: Central Locking Problem
Lexus Owners Club > Lexus Models > LS 400 / Lexus 430 / Lexus LS460 / Lexus 600h
steve2006
A couple of weeks ago the central locking on the front passenger side failed and I diagnosed that as the power and correct signals were reaching the unit it had to be the motor.
So today the door lock assy was completely removed and stripped down ( no mean feat) and the motor in the unit was partially seized ( tested by puuting a 9 volt battery across the terminals). I then sprayed some servisol switch cleaner in the motor and that finished it off altogether.
Anyway reassembled the thing and refitted it back to as it was before and have made some enquiries on ebay for a replacement.
If there is anyone on here with a spare or breaking a car please let me know.
Also am I just unlucky or has this problem occured before with the locks?
M.IQBAL
QUOTE(steve2006 @ Aug 3 2008, 05:02 PM) *
steve there is a silver one beng broken on that auction site - have you tried them? - its definatley advertised as a celsior
regards
miq
steve2006
Thanks for the info,I remember seeing that one, but it may have ended, but it has been relisted before so I will keep looking.
Cheers,
Steve
steve2006
I've just thought ( yes OK it's getting harder at my age!) is the series 2 and series 3 door lock the same?
I would assume so even though there are differences in other areas.
Could someone with a series 3 just have a look at the link below which is for a series 2 and check if the series 3 has basically the same components i.e internal door opener lever and internal door lock buttons in the same place.
The reason I ask is that there are 2 series 3 LS's on ebay being broken and I don't want to buy one to find it won't fit.
Cheers,
Steve
http://www.lexls.com/tutorials/body/fdoorpanel.html
Nitmoi
Try Benfur he was breaking one, he has got me a few parts for a silver series III. Thoroughly decent fellow too.
steve2006
QUOTE(Nitmoi @ Aug 3 2008, 11:00 PM) *
Cheers Nitmoi, I got in touch with Benfur and you are spot on he is a thoroughly decent fellow and he has got one.
Hopefully job sorted next week.
I will take some pictures and do a tutorial for future reference.
steve2006
Firstly may I thank Benfur for all the help he has provided in removing and posting me the door lock assy.
To update the lock arrived today and guess what the series 3 is different both wiring loom wise and the lever rods to the exterior door handle and lock ( or it could be due to mine being a Celsior)
But I successfully stripped down both locks and transfered the motor from the donor unit to mine,reassembled,refitted and it is a complete repair.
I am in the process of compiling a slideshow of the proceedure.
