Just jumped in my car after a days work & it wouldnt start for me first time, tried again & it was a bit lumpy running, pressed the throttle & it died, it keeps doing this now
I managed to get the car under some cover to have a look under the bonnet since its raining outside!!, without the engine running I can hear a small constant buzzing noise from the throttle body, when I manually turn the throttle spindle part the noise gets louder , I tried to disconnect teh supercharger cable but it doesnt make any difference.
Only thing out of the ordinary recently was I noticed that the stainless sleeve for the TTE airbox had went inside the airbox when i tightened the hose clip, the engine had been sucking in un-filtered air for about a week before i noticed
Anyone any ideas whats wrong, anything i can do?
Thanks, Steve D
Steve_D
Aug 4 2008, 05:05 PM
Now noticed that I have two fault codes on the Scangauge - P0105, which according to the help section is Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction
Kazi
Aug 4 2008, 05:21 PM
Was your supercharger brand new or second hand? If second hand was the Piggy back ECU installed? I'm sure its you're piggy back ECU thats failing. I had it happen to me. Fortunately I had a brand new one spare.
Contact TTE and they will send you one out f.o.c
Hope this helps
Aug 4 2008, 05:33 PM
QUOTE(Kazi @ Aug 4 2008, 06:21 PM)
Hope this helps
TTE dont send out new one's anymore mate, thay have run out of them
Re your problem, is the cable fitted correct ? sometimes when not fitted correct, it can duff the motor in the throttle body
Aug 4 2008, 08:44 PM
Sounds like the Black box to me, the throttle always makes that noise, ive figured out, strange how you never notice it till theres a problem though lol.
But yeah definetely the black box, could just be a loose connection.
Steve_D
Aug 4 2008, 08:56 PM
Thanks guys, I'm pretty sure its wired correctly & it is all second hand - I guess it is the black box then, strange as well because after toying with the throttle body it actually started to work again (maybe just a coincidence), took it for a run & it was fine, didnt want to risk it though & left the car at work just in case
Steve_D
Aug 4 2008, 09:04 PM
Ok, so next question is what do i do now! - If i cant get a hold of one of these black ECU boxes that is
aaronabbott
Aug 4 2008, 09:07 PM
QUOTE(durrantie @ Aug 4 2008, 10:04 PM)
why cant you use the hks fcd?
Steve_D
Aug 4 2008, 09:09 PM
Is that one of the things that needs to be mapped, would i need to take it to a specialist?
aaronabbott
Aug 4 2008, 09:10 PM
QUOTE(durrantie @ Aug 4 2008, 10:09 PM)
no mate it basicly does the same thing other members with the s/c have it
Steve_D
Aug 4 2008, 09:13 PM
ok cool, does it wire into the ECU same as the TTE black box?
aaronabbott
Aug 4 2008, 09:16 PM
QUOTE(durrantie @ Aug 4 2008, 10:13 PM)
im pretty sure it does mate,speak to either gord or stav and they'll help sort it
Steve_D
Aug 4 2008, 09:17 PM
THanks for your help, been panicking tonight, anyway - perhaps you can tell me if this is the correct one? Ebay Item number: 140252909258
aaronabbott
Aug 4 2008, 09:20 PM
QUOTE(durrantie @ Aug 4 2008, 10:17 PM)
thats the one
Steve_D
Aug 4 2008, 09:22 PM
Cheers mate, thats that sorted
Steve_D
Aug 4 2008, 09:23 PM
Car will be out of order for a few days at least - can anyone kindly advise how to wire it up
Aug 4 2008, 09:27 PM
You need to make sure you get the STD version.
Heres the wiring:
Black box at the bottom, and FCD at the top
Steve_D
Aug 4 2008, 09:37 PM
Thanks Stav, i've sent an enquiry to the seller. The HKS FCD appears to have similar wire colours to the TTE box, got to be honest i dont understand the upper wiring diagram, the bottom one is fine because it has pin numbers
Tom-18
Aug 4 2008, 09:51 PM
Im thinking of getting one of these too, hopefully will be fitting my kit in the next two weeks My only concern is where to connect the cables from the HKS to as it has no pin numbers?? Is there a diagram of the EXCU with what the numbers are allocated to??
Tom.
Steve_D
Aug 4 2008, 09:54 PM
Just what i'm after Tom , it really seems like its best not to reply on that black TTE box at all!
Aug 4 2008, 09:57 PM
I'll sort something out for you two tomorrow lads.
Tom-18
Aug 6 2008, 05:53 PM
Cheers Stav.
Tom.
Aug 6 2008, 06:42 PM
Red Black box Wire: E2 16 Black Red Black Wire E6 21 White Black
Cut wire: E5 9 Green Red
With the Green wire from the black box going to the ECU side, and Yellow wire to the other side.
Starting from the front of the car, the connectors are E2, E3, (E4 only on auto), E5, E6.
For the HKS FCD, the black and red wires are the same, but the Yellow wire going to the ECU side, and the White wire going to the car side. On Setting 10.
Tom-18
Aug 6 2008, 06:59 PM
Cheers Stav!
When i finally get time off work and come to a meet i think i owe you a beer
Tom.
Aug 6 2008, 07:29 PM
Get yourself to JAE at the end of the month!
Tom-18
Aug 6 2008, 07:59 PM
I will, as im only 15 mins down the road from Mersea Island! The closest show ive ever been to so if anyone need directions or help in or around colchester i can help :D:D Just watch out for traffic police as there pretty hot on modified cars around here!
Tom.
Aug 6 2008, 08:20 PM
Well i'll see you there, got my tent and everything ready. Just a couple of things to do to the car before then and were away!
Tom-18
Aug 6 2008, 08:42 PM
I'm not gonna be ona stand or anything as i never kept up with owt was happening to do with LOC and JAE but will drive there both days as i can be fussed with camping and i live close Will deff pay alot of attention to the LOC stand and hoping to have my charger kit on before! Just hope my car doesnt get broken into like last year! wallet, mobile, satnav, CDholder! the bloody lot! and only went to see where my mate had parked! 5mins i was away from the car!!
Tom.
Steve_D
Aug 8 2008, 05:47 PM
Thanks for the details Stav, just back from a wedding in Birmingham & came back to this the Ebay seller sent me an e-mail saying that the part would have been 2-3 weeks from Japan & he would send a refund grrrrrrrrrr, bought another one online (not e-bay lol)
For now I removed the TTE black box, removed the supercharger belt & running it NA for a bit until i get the FCD
Aug 8 2008, 06:17 PM
Instead of removing the belt you can just unclip the throttle wire so its always bypassing. Means you keep the sound, if not the speed
yemgi
Aug 9 2008, 08:27 PM
You can run with the supercharger without the TTE box, just don't go too high in the revs. I ran 1 month without it and never had any problem. That's what TTE told me to do as they did want to send me a new one.
84Stoney
Aug 10 2008, 04:41 PM
Must have missed this thread somehow!
I have had this problem....twice now!
Stav seems to have sorted ya out though!
Don't bother un-hooking it. Runs fine just without the box. Just take it easy or it will fuel cut!
Steve_D
Aug 14 2008, 10:44 AM
QUOTE(sparkystav @ Aug 6 2008, 07:42 PM)
Stav, just getting around to this today regarding the red wire, is that supposed to go to E2 pin 8?, thats whats on the standard TTE ECU drawing.
Cheers, Steve.
Monster-Mat
Aug 14 2008, 10:56 AM
if the mechanical cable from the throttle body to the bypass is to tight(no slack) or tight to move it can put undue stress on the motor in the throttle body and throw a fault, maybe lubricate the cable sleeve and see if it is slack enough
Steve_D
Aug 17 2008, 11:10 AM
Earlier on in this topic I mentioned a noise from the throttle body area, I managed to get a video of it can someone please help diagnose whether this noise is normal or not?, turn up your speakers & hopefully the you tube video works
Please wait a few seconds for Video to Load!
Aug 17 2008, 04:06 PM
As far as i know, thats normal mate, its the throttle control.
Steve_D
Aug 19 2008, 07:20 PM
You were 100% right Stav, moved the throttle about on another IS200 & it sounds just the same phew.
Car is running sweet now with the HKS FCD, found setting 9 to work better for some reason, 10 seemed a bit low in power.
Steve.
