Full Version: Amp Bypass Cable, Pictures..
Lexus Owners Club > General Lexus Forums > Lexus Work Shop (Submit your Tip!)
aztecbandit1
Thought i'd do this as i was bored whistling.gif Usual workshop disclaimers apply smile.gif
The whole job takes me about 20 mins from start to finish and you dont even scrape your knuckles which is nice and hope it helps someone as it was a quickie biggrin.gif
Drop the glovebox down by squeezing the side inwards and let it drop down, At the rear you will see 2 pins push these out and remove the glovebox to make access to the amp a bit easier,
And in the picture where you pull the dash out a bit, Before you pull at it just pull the door rubber away a little as it helps the dash move enough to pull forward,
Then follow the pic's..
Bazza
excellent walkthrough
spikes
aztecbandit1
Cheers guys biggrin.gif I was bored so thought i'd have a quick go at it, and being as a few members have asked how its done, biggrin.gif
Parthiban
Damn that is brilliant mate, I didn't realise it was so easy to get the amp out completely like that to actually get at the cable.......
Get walkthrough Chris,
You can also just unplug the other lead and take the amp out fully as well.
aztecbandit1
QUOTE(sparkystav @ Aug 4 2008, 09:41 PM) *
Great walkthrough Chris,
Yeh i know matey but doesnt need to come out if your just fitting the bypass lead.
It shows how bored i was, as i havn't even fitted an aftermarket headunit yet just wanted something to do so thought i'd take my car apart laugh.gif
You could have spent it making a cover for me!
offtopic.gif did you find the dimensions for me?
aztecbandit1
QUOTE(sparkystav @ Aug 4 2008, 10:56 PM) *
Very offtopic.gif Not at work mate on holiday for 3 wks but have the template here just need the metal to do it?
TigerFish
84Stoney
I, like many, did this without removing the amp....and it was a ****** to do!
