Full Version: Headlight Washer
Lexus Owners Club > Lexus Models > LS 400 / Lexus 430 / Lexus LS460 / Lexus 600h
kenmac
The headlight washer doesn't work on my LS400,but I cant find the fuse in the fuse box by the steering column,on the cover I have a fuse location for a 30A that says P/W which I presume is Power Wash but cant find the fuse,or can anyone tell me where the motor is?
M.IQBAL
have you tried with the headlights on? thats how they worked on the pajero i had - i cannot remember wether this applies to the lexus.
its a feature which very rarely gets used - i have never used mine in the past 9 months - will check it this weekend just to make sure its working
regards
miq
kam05
QUOTE(M.IQBAL @ Aug 6 2008, 03:32 PM) *
On the IS200 you need to switch the headlights on for the headlight washers to work- its probably same for the LS400 as well. Also make sure you have enough washer fluid in the washer tank.
kenmac
Thank guys,yes the lights have been on when I tried
jom
I recently had a prob with my washer but that was more to do with the bracket, however on the IS200 I've been told the washer works off water pressure and not a motor, and you do need to have the lights on.
steve2006
Fuse should be # 12 (WIP) rated at 20 amps but this also protects the windscreen wipers and washers too so if they are working the fuse isn't gone.
When you operate the washers can you hear a motor/pump running?
kenmac
QUOTE(jom @ Aug 7 2008, 02:31 PM) *
Cheers Jom, the LS works on a motor as there is a fuse for it but I do wish it worked the same as an IS.
kenmac
QUOTE(steve2006 @ Aug 7 2008, 07:51 PM) *
Wipers are OK so it's definitely not the fuse,but no sound from the motor/pump,would you have any idea where it's located please Steve
steve2006
QUOTE(kenmac @ Aug 7 2008, 11:54 PM) *
It should be located in the left front corner of the engine compartment behind the headlight.
