QUOTE(Matrixabc @ Aug 11 2008, 01:08 PM)
Hi, On my LS430, after a night of heavy rain , when I reverse one of the rear sensors comes on all the time:-
- has any one fixed this problem?
- do they pull out through the front , or is it a bumper off job?
- How much are they each?
when it dries out is works normally again.
thanks
Hi
You can pull them out through the bumper, mine have a small in line connector on the end and there is enough slack to get to it. Had three replaced when it got rear ended earlier in the year the inner ones were just over £200 each and the outer one was a positive bargain at just under £200..... cheaper to employ someone to stand behind you.... Mine is an earlier car though so they may be different...
Pete
