Greedy80
Aug 13 2008, 03:05 PM
This is my car after several hours of careful washing and polishing! But god damn those stone chips why oh why are they there?! I only have a couple but they're on the bonnet.
To detail the car I used Turtlewax premium car wash shampoo, I rinsed the car with several buckets of water first. Next I had two buckets prepared one of soap and the other in just plain water, using two micro fibre washing mits I soaped the car up and rinsed each panel individually. Next I used a chamoise on the window on both the internal and external windows. I then used a dry turtle wax micro fibre towel to dry the car and prepare it for waxing.
Before I got stuck into the polishing I cleaned the alloys using a bucket of water and Simonz alloy cleaner and break dust barrier. I treated each wheel twice to increase the shine, however I do need to remove the the wheel centre pieces at some point and clean these separately as the dust seems to grip the chrome with particulalry harsh avengence. Any suggestions on what to use guys?
Anyway next I used some turtle wax Ice and an abundance of micro fibre cloths two shine up the surface of the car. This is the first time I've used Ice, I was going to use turlte wax premium car polish (the traditional white stuff) but the idea of no white streakiness creeping on to the plastics was encouraging. I have to say I'm very impressed with Ice and I'll use it again and again, I don't think it'll replace some of the better maguire's stuff out there but for a top up wax it's perfect. It applies easily and being clear it doesn't effect any of the trim in fact it can be used to clean all but the windows. The only thing I woluld say is that you need to keep track of the areas which have been polished and those which haven't. Because the liquid is clear and when it sets in it just slightly makes the surface of the paint look dull (until buffed) it is easy to not even notice that there is polish on the surface. To be honest though this could just be as a result of a dull morning and the fact that my car is platinum ice and as such doesn't help matters in this area. Also I should add that buffing the car once the polish is applied is much easier than with a traditional polish, it literally takes half as long to do the whole car. On the whole I was so pleased with the result I'll definately use the same products again. It rained the next day but that didn't put me off too much, it's always nice to see the water ball up and roll off of a freshly polished bonnet.
PS. Sorry about the pics, they don't do it justice it was low light
PPS. Does anyone know of a good way to remove the dealer ship sticker on the car? I have a 'dorchester collection sticker on the paintwork, It's a pain. Thanks
Greedy80
Aug 13 2008, 03:28 PM
Here is a pic of the sticker on the rear of my car, it's the red one in the bottom left hand corner.
Thanks.
Aug 13 2008, 03:35 PM
Good effert mate
have you tryed some heat to remove the sticker, to make the glue soft
Greedy80
Aug 13 2008, 03:54 PM
QUOTE(Gord @ Aug 13 2008, 04:35 PM)
Good effert mate
I haven't yet mate no but I figured that would be the way ahead, just a little nervous of applying too much heat. I just wondered if there might be someone here who has done the same thing succesfully and had any tips.
ta for your reply though.
Aug 13 2008, 04:06 PM
QUOTE(Greedy80 @ Aug 13 2008, 04:54 PM)
Good effert mate
Yer mate use some heat, then try putting fishing line under it to help pull it off, then remove the glue while still hot/warm
dgman
Aug 13 2008, 05:50 PM
heat it up with a hair dryer and peel off,no problem.
aztecbandit1
Aug 13 2008, 08:39 PM
Looking very nice matey, good job you've done there
Aug 13 2008, 11:33 PM
nice colour too
Greedy80
Aug 14 2008, 09:05 AM
QUOTE(dgman @ Aug 13 2008, 06:50 PM)
Thanks for your comments guys, ok so I'm gonna go for it with the hair dryer. I don't suppose anyone could refer me to a good chemical that will help remove the excess glue on the paint work? I don't want to miss any glue and then have it pick loads of dust and dirt creating a scabby patch on the rear of the car.
Aug 14 2008, 09:08 AM
QUOTE(Greedy80 @ Aug 14 2008, 10:05 AM)
Glue should come off when warm/hot, but if not try sticky stuff remover from halfords, it in spray tin
Greedy80
Aug 14 2008, 10:29 AM
QUOTE(Gord @ Aug 14 2008, 10:08 AM)
Thanks once again mate, I will do and I'll let you know how I got on.
This forum is quite simply the best I've ever used the community on here are very helpful, i suspect many lexus owners have saved a fortune by reading these forums.
dgman
Aug 14 2008, 04:10 PM
just use methylated spirit then reapply your wax or sealant,its also very good at removing tree sap and bugs and tar spots.
PJ S
Aug 14 2008, 04:42 PM
Don't know about meths - but I'd suggest IPA (Isopropyl Alcohol or Isopropanol) or Panel Wipe (same thing) diluted 50% or 75% strong.
Neat maybe for tar.
Gives the wax/sealant the cleanest surface to adhere to.
dgman
Aug 14 2008, 04:47 PM
QUOTE(PJ S @ Aug 14 2008, 05:42 PM)
Neat maybe for tar.
meths will do the same as ipa but without the cost.
dazz32
Aug 14 2008, 04:57 PM
If you ever need to get tar spots of use WD-40 and a soft cloth....then wash N wax after....comes of really easy...and dont cost to much.
WylieCoyote
Aug 15 2008, 07:44 AM
QUOTE(Greedy80 @ Aug 14 2008, 11:29 AM)
Many people have saved a fortune, others have spent a fortune!!
click here.
