ok split with the girlfriend so have to sell up, gutted!!!
Ok this is a 1993 LS400, i have put quite a few threads up in the past so please feel free to check them out. i have stripped and rebuilt this car inside out for the past year and a half and only drivin it a hand full of times. Here is a list of some of the things that i have done:
1, Stripped all the body work off to wax oil behind everything
2, Repaired the broken ariel
3, Stripped and cleaned out throttle body
4, Changed the Drive belt
5, Cleaned the Engine bay
6, Replace nearly all the plastic covers in the Engine bay
7, Stripped out the boot its now been grit blasted and respray
8, Repaired the auto changer and housing
9, Cleaned all carpets seats and ALL internal trims - this involved removing everyone and taking them home to be cleaned
10, Realigned all the doors, boot lid, and bonnet as they were out of sink
11, Repaired the dash as it didn’t work - £1.00 well spent
12, Stripped the dash so I could clean and repair bits
13, Repaired roof trim as it was falling down
14, Installed Amp and housing for new sub
15, Repaired all side skirts, front and rear bumper, and replace a rear door quarter
16, Sanded down all rust spots ready for re-spray
17, De-badged
18, Tinted rear and side lights
19, Cleaned up exusts using Autosol
20, Full Service
21, Installed a 10” sub
22, Custom made a sub box to fit around the fuel tank
23, Sound deadened the parcel shelf and back seats
24, Finally got the rear fog light working – put my own cables in
25, Put on clear indicators
26, Fitted halogen bulbs
27, Lowered the front by 31mm and the rear by 25mm and then put original springs back on, I still have the springs.
28, Fitted Superflex bushes to the front control arm
29, Fitted Superflex bushes to the rear trailing arms
30, All brake discs have been filed and cleaned up
31, New pads on the front and new shoes on the rear
32, All calipers have been taken off, cleaned up and painted.
33, Most importantly managed to replace the Lexus tool kit in the boot.
34. Fitted gas struts to the boot
35. Fitted new CD player and Autochanger
36. Fixed Faulty windscreen fluid indicator
37. Fitted Front and Rear Strut Brace
38. Fixed faulty electric mirror switch
39. Windows tinted
40. Replaced front windscreen
41. Replace the air filter for a K&N Filter
42. Put 18” Deep dish rims on
43. Had the car resprayed
44. New number plates
45. Painted Rear hubs
46. Modified Rear arch lip and then coated it with stone chip
47. Stopped the water leaking into the boot
48. Painted the a-pillar trims next to the glass
49.Fixed the rear heat shield back up as it was rattling on the exust
50. Replaced nearside rear wheel bearing and seals
I have not cut corners on this car and is a great car all round. I also have a box full of bits and all workshop manuals to go with the car.
Some pictures:
http://i149.photobucket.com/albums/s50/Lin...ppedawesome.jpg
http://i149.photobucket.com/albums/s50/Lin...IMAGE_091-1.jpg
http://i149.photobucket.com/albums/s50/Lin...22122007215.jpg
http://i149.photobucket.com/albums/s50/Lin...01032008484.jpg
if you would like more pictures please feel free to email me. I'm asking £3,500ONO and if i get near that i will you give a years MOT and a years tax.
There has been thousands spent on this all backed up with reciepts and photos.
Please email me if require further assistance
Mat
