However, I hit a slight problem. The connector for my dipped headlamp and the connector on the HID kit didn't quite fit together properly. It looks like the connector on the HID kit is slightly too recessed for the two to be able to contact properly. I had a minor panic when I got them jammed together in an attempt to "make" them fit, but after perseverance I eventually prised them apart !
Did anyone else with the HIDS4U kit have this same problem ? Don't know if the connectors have changed at all, my IS200 is a 1999 model.
I wanted to check what others had done before starting to hack off bits of plastic, in case I'm missing something obvious !
