Hi there, wondering if anyone out there can tell me wether I can swap a 5sp auto IS200 speedo with a 5sp auto RS200Z?
Would it work properly?
Any comments are welcomed.....
Thanx in advance
ricky_is200
April 14, 2003, 12:31 pm
I thought the IS200 auto was a 4 speed.
Monster-Mat
April 14, 2003, 3:40 pm
it is
im not sure it would work,...........
do you have an oil pressure guage on your cluster.......
hmmmm, i think it will, if it dont, sell the cluster on ebay
cdawg
April 19, 2003, 4:53 pm
I am in the US and have a 2002 IS300 MT. If you can figure out what we need to do to swap the guage cluster, I'll swap with you. Mine has a mpg meter where yours has an oil temp, otherwise I think they are the same but I'd have to know what's involved in the swap before executing. Let me know if you are interested.
Monster-Mat
May 10, 2003, 2:16 pm
from what i can gather the printed circuit for the Altezza guage is different to the IS200/300 one, if you can do micro-electronics, getting the oil guage to work should be no problem.
a problem that should be looked at though, is the speedo calibration........you may need the altezza speed sender, also the problems could lay with the instrument ECU located behind the dash
