tys
Aug 17 2008, 06:19 PM
Hi evry1.im new to the forums.i recently bought a x reg is200 se.a cuple days ago the MIL came on.does any1 knw what the most common prob mite b?is it worth me buying a obd2 scan tool of ebay? thanks for looking tys.
Mark W
Aug 17 2008, 06:25 PM
hi and welcome to loc... You need to find the codes as the light could mean anything...either pop into a garage (some will do for free but most charge) or get yourself an obd2 reader ..which will prob pay for itself anyway after 1st use.
Unless there is someone local who has one....but for 35 quid or less I'd get one anyway
Once you have the codes post them on here and there will be plenty of folks who can advise
tys
Aug 17 2008, 07:09 PM
thank for the quick response. does anybody think this would woul be suitible ebay item num.160270993863. jst as an idea i nearly ran my tank out of fuel the othe day and was drivn round bend quite fast.fuel light was on.i filled up to half a tank then the MIL came on while i was drivn home.jst andea as it mention in the owners manual that the light mite come on if tank is low.bt i reset the ecu light went of bt comes back on after 50miles or so.
Welcome mate, as advised get yourself areader, you can get a stand alone Reader/reseter pretty cheap, or a reader to plug into a laptop as well.
Then look here:
ClickyFor the code and that'll tell you your problem.
Aug 17 2008, 07:11 PM
And yes that reader should work with your car.
tys
Aug 17 2008, 08:09 PM
hi thank for the responses.ive jst bought a reader so il let u all knw how i get on as soon as i get it thanks.tys
Steviewevie
Aug 17 2008, 08:21 PM
Wow I didn't realise these readers were so cheap
I suppose that ordering one while the car is running fine is probably a good way to ensure that it doesn't come up with any faults !
tys
Aug 19 2008, 04:30 PM
hi everyone reader came 2day.yey!lol.and it works a treat.the code i got was p0420.according 2 my book it states" catalyst efficiency below threshold(bank 1)".does any1 knw how 2 fix this prob?
ProLex-UK
Aug 19 2008, 04:52 PM
Go to lexus...............
tys
Aug 19 2008, 04:58 PM
not the price they charge.lol.before light came on i had nearly run the car out of fuel.so mite be dirty fuel i the system or i changed my exhaust 4 a cat bac system so i mit have damaged the o2 sensor? anyone with any ideas?
Aug 19 2008, 05:25 PM
Seems like your cat might be knackered to me.
tys
Aug 19 2008, 05:32 PM
i did read that somwhere bt they should in theory outlive the car.it mite have been the fuel i put in?it was shell unleaded bt who knws.im guna ave a luk under the car 2 nite 2 check the sensor cuz i jst unscrewed it without uncliping it!mite b that.
tys
Aug 19 2008, 07:39 PM
tink i found the prob!!the wire where twisted so i un-tangled them and also the joint on the cat jst b4 the last sensor was leaking.so ive sorted that and reset the ecu with my new reader wich is an ace bit of kit.
Aug 19 2008, 08:42 PM
QUOTE(tys @ Aug 19 2008, 08:39 PM)
Hope it all works out for you
finchy
Sep 24 2008, 01:45 PM
QUOTE(Gord @ Aug 19 2008, 09:42 PM)
just wondering if it did?
tys
Sep 25 2008, 06:50 PM
yea the light has not come back on since(touch wood lol) it was because the joint in the exhaust system after the cat was leaking an was not passing through the 02 sensor properly.
finchy
Sep 25 2008, 07:18 PM
glad to hear it mate, because i got the same code myself the other day.
got a print out from OBD11 CODES.COM.
and it said as much about the o2 sensor and/or a couple of other minor stuff.
i'll keep my fingers crossed for ya.
i've reset mine so here's hoping
ibanez
Sep 30 2008, 11:23 PM
what scan tool did u buy?
Oct 1 2008, 02:32 AM
I have a scangauge fitted to mine, excellent piece of kit.
click here.
