Full Version: Sprint Booster On An Is220d
Lexus Owners Club > Lexus Models > Lexus IS 250 / Lexus IS 220D / Lexus IS 250C
Scarlet Pimpernell
See http://www.sprint-booster.co.uk/how_to_ins...rintbooster.asp this link.
A lot of the BMW and Merc Forums have threads on this device. I looked up the IS and no Lexus is mentioned. It does state that you need flybywire throttle. Don't know if Lexus's have FBW, but Skoda's and Fiats do...so assuming it does?
Has anyone come across this, and could this help with the flatspots?
Parthiban
I'm pretty sure the mk1 IS is fly by wire, so I'm sure the mk2 is - can't really see the point of that though, is it just making the throttle more sensitive? unsure.gif
ProLex-UK
TOM's do a device which improves the throttle response..............gives no more power but means when tou press the throttle there is no "dead time" has 4 way adjustment
illestjt
QUOTE(ProLex-UK @ Aug 19 2008, 06:09 PM) *
http://cgi.ebay.co.uk/TOMs-linear-throttle...id=p3286.c0.m14 ?? is this it?
Maz
wouldnt this be better option? http://www.dieseltuningbox.com/lexus.html (thank for the link Illestit), just want to know if anyone here had tried this device yet....
dgman
QUOTE(Maz @ Aug 19 2008, 09:06 PM) *
a unit called the spider was mentioned some months ago by nate 73 who i think has since defected to audi,i don't know if he ever installed one though.
Maz
found it, sound like the one i mention above.... http://www.dieseltuning.co.uk/lexus-diesel-tuning.html with this one its 1bhp more and 10nm more Torque than the one above...
dgman
QUOTE(Maz @ Aug 19 2008, 09:50 PM) *
are you tempted.
Maz
aye, but would like to find someone who had it done first just to see how good it is... whistling.gif whistling.gif whistling.gif whistling.gif
Anees
I got one on my 330D. Nice peice of kit, but not worth £140 odd quid in my opinion.
gooseygopher
QUOTE(dgman @ Aug 19 2008, 09:13 PM) *
I have this unit installed, did it on sunday. Makes so much difference. You can feel the extra power, the car has less of a flat spot before the turbo and the torque is awesome, just testing the mpg at the moment. So far im averaging the same but havent really drove economically yet, although i did today and was getting in excess of 48mpg
dgman
QUOTE(gooseygopher @ Aug 20 2008, 02:52 PM) *
is there any change in your insurance premiumand can you let us know some details of the fitting procedure,can you remove the unit easily in case of lex dealer visits.
Lex Bhoy
QUOTE
My other car is an Astra Sri 150 and there are plenty of guys running around with these, some guys have declared it as a fuel saving device and gotten away with it... after it does save fuel but also put the bhp up a few notches
It is a box that connects to the diesel pressure sensor and it alters the voltage, this results in the diesel being injected at a higher pressure whcih results in a better combustion whilst being more efficient... I think... blush.gif
Can be removed easily enough for visits to dealer....
Just got the Astra and will be investing in one next month
Fitting Instructions
dgman
QUOTE(Lex Bhoy @ Aug 20 2008, 09:29 PM) *
QUOTE
is it the lexus that you have this fitted to or the astra.
Lex Bhoy
QUOTE
Not fitted to either yet but will be going for the Astra
Maz
but did you had a 5th Injector recall done? i had my done and the flat spot problem seem to be gone, so unless this device make it alots better even after the 5th injector recall, then i will question if its money good spend. also which one you fitted to your car? Spider® diesel tuning system or the Venom system?
Regards
Maz
gooseygopher
QUOTE(Maz @ Aug 21 2008, 12:37 AM) *
Regards
Maz
the unit took 10mins to install, its the spider unit which constantly updates to provide performance or economy depending on how you drive. You simply connect the unit into the common rail socket and attach the unit to the battery and your done, all instructions are included. I havent had the fifth injector done, my 220d is a 57 plate. It still has the turbo lag at low revs but its so much better now than before and im afraid that 6th gear is still quite poor, however there is some improvement. Im off to London today so ill let you know what the mpg is like after the journey. I drove through Notts yesterday though and was averaging 48mpg.
Scarlet Pimpernell
My whole point for raising this was that th flatspot on my car as getting worse with mileage, or so it seemed. And the threads on SB seem to indicate that it improved throttle response, which seems pretty dire on the IS220d compared to any of the competition.
There is a distinct diffrence in what is available from what I have gleaned:
The SB only "enhances" the signal, so it does not actually affect warranty or insurance. It doesn't change the mapping or output. Just makes it more sensitive and clear...
The Spider and other devices like Venom DT can actually increase BHP and or change the ECU mapping. For that you really do need to be careful. Both Insurance and dealership approval should be sought, though most people just flunk it.
PS - Gooseygopher - 6th is distinctly an Autobahn gear....even my handbook stated that it was recommended for use at speeds greater than 75mph...
mark_hk
I had a sprintbox for me ES300 here in HK. I think they are a great bit of kit. Improves throttle response as soon as you plug it in! It definetely gave my ES a bit more punch. Not sure how it really works, but will have one installed when I look to buy a SC430 in the next couple months...
crazy-dee
do these work for the petrol engines aswell or diesel only ?
would it go fine on a is200 ??
mark_hk
My ES300 is petrol and works brilliantly.
As long as the car is throttle by wire then it should work! I paid approx 150 quid for mine here in Hong Kong
Rob
for those wondering about the is200 unfotunatly it is not throttle by wire, it is a mechanical input with electrical trimming so this device will not work on an is200
