Full Version: Epc Data
Lexus Owners Club > Lexus Models > Lexus IS200 / Lexus IS300 / SPORTCROSS
Monster-Mat
[u][b]Locate Part Number. (Toyota Part Number)[/b][/u]
Put in a request, by PM i will find it and add the part number here
[img]http://i5.photobucket.com/albums/y179/SteveHammatt/IMG_2265.jpg[/img]
Monster-Mat
PISTON, FRONT DISC BRAKE
47731‑30170 GXE10, JCE10 QTY 4
CYLINDER KIT, DISC BRAKE, FRONT (re-build kit, contains boots, rings, seals and paste)
04479‑30191 GXE10 QTY 1
ABSORBER ASSY, SHOCK, REAR RH
48530‑80163 GXE10, JCE10..SED..EUR; MARK 48530-53041 QTY 1
ABSORBER ASSY, SHOCK, REAR LH
Monster-Mat
PIN, FRONT DISC BRAKE CYLINDER SLIDE
47715‑30060 GXE10, JCE10; MAIN QTY 2
BOLT (FOR FRONT DISC BRAKE CYLINDER SLIDE)
90105‑08164 GXE10..RHD; GXE10..LHD..ATM; *8-1.00PX23-15 QTY 1ea
Monster-Mat
Caliper rebuild kit - does this come with 4 of everything (i.e. 2x seals, boots and set rings for both left and right sides)?
[color="#ff0000"]YES
[/color]I understand the top slide pin is different to the bottom - bottom should have sliding bushing whereas top doesn't? What is part no. for sliding bushing?
[color="#ff0000"]Bush Slide Cylinder No 1 (Front Disc Brake)
47769-50010 GXE10, JCE10[/color]
What is part no. for dust boots?
[color="#ff0000"]
Boot Bush Dust
47775-30070 RHD GXE10[/color]
Can you buy the pistons individually?
[color="#ff0000"]
Post number 2 ...above, first item listed[/color]
Invision Power Board © 2001-2010 Invision Power Services, Inc.
