Full Version: Tire Pressure Sensor
Lexus Owners Club > Lexus Models > LS 400 / Lexus 430 / Lexus LS460 / Lexus 600h
timtruong
Hi everyone,
I owned a lexus 460 and the low tires pressure indicator is on. I checked the pressure and everything is OK. does anyone have this problem and how you can turn off the low tires pressure indicator. I live in Vietnam and there is no Lexus dealer here so any help is greatly appreciated.
Haylands
QUOTE(timtruong @ Aug 24 2008, 12:05 PM) *
Hi everyone,
Hi
I'm sure I read somewhere about this being due to flat batteries in the wheel sensors, to replace them is very expensive, sorry haven't a clue how to turn it off....
Pete
jsj24uk
If it is anything like on my LS430, which it probably isn't, in the drivers footwell underneath the knee airbag is a button with the word tyre just above it. Inflate your tyres to the recomended pressures and then hold the button till the screen gives you a message. Mine came on a couple of times on my last long drive. All tyre pressures were fine so I just reset the indicator. No problems since.
Hunt.trophy
Just above the accelerator pedal are two buttons, one says tyre on it as well as a knob to adjust the beep level.
Press and hold the button till you hear a beep. At least 5 seconds. This will reset the pressure gauges.
Simple solution.
steve2006
Or he could send the car over to me in the UK to look after until the fault goes away whistling.gif
mahmoodkh
QUOTE(timtruong @ Aug 24 2008, 03:05 PM) *
Hi everyone,
hi
in ls 430 there is a reseting button below the steering wheel , check it and if it is in the same location as my car just press it for 4 seconds then the alarm will disapper.
good luck
