Full Version: Veggie Oil Fuel Conversions
Lexus Owners Club > Lexus Models > Lexus IS 250 / Lexus IS 220D / Lexus IS 250C
Steve
Would anyone consider a conversion in their diesel from diesel to veggie oil?
The savings are great!! Even better if you can get used veggie oil. But even new veggie oil is a big saving.
See this conversion: http://www.dieselveg.com
you can do it without.
I fancy getting an oul diesel run about and stick veggie oil straight in, happy cheap motoring around town, and dont pay mr brown.
Monster-Mat
from what i understand...you cant use veg oil on modern direct injection diesels...successfully, i wouldnt want to run the new toyota diesels on it, put it that way
also, look at the price of a litre of veg oil in Tesco.......
it aint much of a saving
Steve
Read the FAQ mate.. can be used on modern engines, from what they say.
Also dont go to tescos, go to the suppliers who supply chip shops.
Chip shops can supply used where you need to filter it and register with customs as a home producer. its about 27p a liter in tax. Total about 30p per liter in fuel after costs, happy days!
From the FAQ
QUOTE
Can the new generation of diesel engines (direct injection, common rail) be operated with vegetable oil?
Yes new technology is available
aaronabbott
5 of the lads where i work have done this for the past few years without any problems and every so often they just put in a fiver of diesel just to help,
but like mat said i wouldnt fancy doing it to a brand new diesel
Steve
oil suppliers from 20 litre to 1000 litres
http://www.ktc-edibles.co.uk
Monster-Mat
i still wouldnt put it in a Modern direct injection Diesel.
dgman
it's a bit worrying when you read the disclaimer .
Steve
mat, your truck should be able to use veggie oil no sweat
Monster-Mat
QUOTE(Steve @ Aug 25 2008, 08:44 PM) *
peter026
You are allowed 2500 liters per annum without paying duty. I use bio diesel in my truck and top up with diesel, as I can only get 25 liters per week from my supplier. He recycles used sunflower oil from the local crisp factory, and this goes through, I believe at least two filtration systems, then heated to a certain temperature to remove any water
Then the last process is to have the glycerin removed.
Using neat veg oil, unless diluted with mineral diesel, can gum up the injectors. Some people add a liter of unleaded to dilute it even more
This Linky might provide an insight to the use of Veg oils
Scarlet Pimpernell
My new car actually states "No Biodiesel" on the fuel cap....
Dunno if anyone saw the Pulling Power (or was it 5th Gear??) a couple of years ago - they famously ran an old Merc Diesel on 2nd hand chip shop fat. It ran as well as Diesel, same performance. economy etc.
In fact I am led to believe that the first diesel engine was designed to run on fat/oil.
I really don't know about the facts of being able to run a modern Turbo Direct Injection diesel on cooking oil, but even at Asda, 1 litre of Cheapo Veggie oil is the same cost 1 litre of diesel at their pumps laugh.gif
ASDA Vegetable oil 1LT
Use oil and spreads in moderation. These oils are high in good fats and healthier for your heart
£1.19
£1.19 per l
Mind you, it is low in Saturates and high in Monosaturates wink.gif cool.gif
peter026
The first diesel engine was designed to run on Peanut oil
eXOBeX
I've heard that you've got to be careful with used veg oil. If it's been used for cooking chips, fine. If it's been used for meat (sausages for example) the animal fat can clog the fuel line.
Could try the Chineses, apparently they change their oil more often than the chippies do.
