QUOTE(LexHead @ Aug 27 2008, 11:15 AM)
Hi Folks,
Long time reader - first time poster.
I'm going to go ahead and buy my first Lexus in the next couple of months. After lots of reading and research i've decided on either a 2000 LS400 or a 2001 LS430 (my budget suits this).
I know that the last of the LS400's are ultra reliable - but on the other hand a newer model would be nice too. So what do you think? Are the first of the LS430's as good reliability wise as the last of the LS400's?
Any advice to help me decide would be appreciated.
Hi......
Well what a question.... this is my personal view it is not the view of the management or anyone with a late 400....
I had this dilemma as well, in the end I decided the 430 suited me better, it’s quite a bit bigger inside and you sit higher, there are more knobs to play with...
I drove both and to me there was a massive difference between them, you could tell that 80% or so of the 430 is new.....
I have had mine a 2001 for just over a year now and done 20,000 miles in it (bought with 57000, now has 76000) It has been serviced by Lexus only.
Everything on it works, every button does what it should....
I replaced the boot struts when I bought it, apparently these go through lack of use!!! (Cost about £70 for the pair)
The only failure I have had in the 20000 miles is one rear bulb!!!!!!!!!!!!!!
Seriously, nothing else has gone wrong, yes I've put tyres on it and a parrot Bluetooth kit and an IPod adapter but the car itself just works, from the soft close doors and boot to the aircon seats and superb sat nav....
If you can afford a 430 I would go for it, the 400 was a great car but the 430 (In my opinion) is much better....
If you buy one check the following
1, Sat nav disc... has it been updated (latest one is about £130)
2, Does the boot stay up when opened, you have to lift it yourself it doesn't open on its own but it should stay up when fully open.... (£70 for new struts)
3, Tyres.... the inner edges wear, check front tyres on full lock (£70-£150 a tyre depending on make)
4, Check every single button, this should take about an hour..... Do they all work??
Apart from that it’s just the usual second hand car checks, Lexus will inspect a car for you for about £55-£60. I had mine done when I bought it, the only thing they noted was that the high height air suspension setting only raised it 14mm... anyway that was probably due to lack of use as it rises 20mm now...
Good Luck I am sure there will be lots of other thoughts on here soon...............
You don't say where you are but if you are near Hull and want a look/ride/play with a 430 then let me know...
Pete
