shanem
September 3, 2008, 1:43 pm
[quote name='Robin H' post='578450' date='Sep 3 2008, 01:10 PM']I used to run a TRD ligtht weight flywheel with a standard clutch and it worked fine ( I have the old flywheel for sale if your interested )
Now I'm running a light weight Toda flywheel and Helix cermertalic clutch,
The IS200 and RS200 use the same clutch just the flywheels are different, so you may want to look at a road clutch as this will be a bit nice to drive with ( not as heavy to drive )
it really just depends on how much power your gonna put throught the transmission and how much you wanna spend[/quote]
Thanks for the reply mate
I dont want to go crazy with the spend although its not an issue... I do like to put the foot down quite a lot on private roads
Can you explain exactly what you mean "how much power your gonna put through the transmission"? I've been driving for 15 years and have only just started to take a real interest in how things actually work and i can see now how addictive it can be
So is it best to order a IS200 clutch kit from Toyota? or will they totally fleece me ? and buy a light fly wheel from? Where did you get your Toda? and do you literally just need the wheel or do you also need special covers and bolts etc?
I'm worried about a few things... 1st that i'm going to get robbed when i could have got the same parts elsewhere for much cheaper and 2nd that because of my lack of knowledge i'm not going to get all the parts i need for the job
Cheers for the help, much appreciated
btw thanks for the offer, but i think i'd prefer to buy everything new
