September 13, 2008, 2:56 am
[quote name='5chulzy' post='582207' date='Sep 12 2008, 06:37 PM']1- to have led strips located underneath each front seat and in the footwells that can either be switch on, off or come on with the courtesy light and fade out.[/quote]
I didn't bother with strips under the front seats as I never travel in the back, and rarely have back seat passengers.
This is two 12" long RED LED strips (cost about £13 inc postage from E-Bay). They are wired soley to come on as
the dome light does, and fade out in exactly the same time/manner.
[url="http://s176.photobucket.com/player.swf?file=http://vid176.photobucket.com/albums/w163/djwozza/Vid1.flv&fs=1&os=1&ap=1"][img]http://i176.photobucket.com/albums/w163/djwozza/th_Vid1.jpg[/img][/url]
[quote name='5chulzy' post='582207' date='Sep 12 2008, 06:37 PM']2- to have courstesy lights under each door so when opened lights up the ground oustide the car[/quote]
I believe Yaumeister was attempting to do a similar thing, but ran into problems. It is possible, but I wouldn't
suggest using the door marker lights as a feed, but maybe as a trigger for a relay to switch them on/off.
I would suggest there is no need for a delay as you wont see them fade with the door in the closed position
[quote name='5chulzy' post='582207' date='Sep 12 2008, 06:37 PM']3- to have some lights under the wing mirror so when the car is unlocked with the key fob they light up the ground by the car (thanks parthiban)[/quote]
Would have to be inlaid into the mirror housing to look good IMO, but deffo possible using a parrallel feed to the dome light
to work in exactly the same way as the footwell courtesy light.
[quote name='5chulzy' post='582207' date='Sep 12 2008, 06:37 PM']4- white led eyebrows for my sidelights with a smaller orange strip next to it for my indicator[/quote]
Yaumeister has yellow lightbrows running along the top of the headlights connected to his indicators
to flash in time I believe (but maybe timed to flashe exactly opposite, I can't remember which way).
[quote name='5chulzy' post='582207' date='Sep 12 2008, 06:37 PM']what colour do you guys think i should go for on 1, 2 and 3 white/blue/red/????[/quote]
entirely up to you, I went with a Red LED colour scheme as evryone else had gone for Blue or White interior LED's.
I would suggest white so long as the LED's are not too bright. I have
Red Glovebox Led's
Red Dome Led's
Red Map Reading LEd's
Red Footwell courtesy lights
Love them to bits
When fitting these lightbrows, a quick blow 250mA fuse was fitted with mine along with a Diode to ensure electrical safety.......
Fuse everything you are going to fit !! Better to be safe than sorry matey.
I will be at Folkstone either Tuesday or Weds this week, send me a PM if you wanna hook up and take a look at mine,
or need any further info etc whilst I am down your neck of the woods.....
