roundymoony
September 18, 2008, 11:02 pm
hi guys,
I just wondering have any of you any ideas as to how I could remove the haze on my head lights?
ive tried washing up detergent but makes no difference.
I would appreciate any suggestions.
cheers
aztecbandit1
September 18, 2008, 11:12 pm
Try T-cut or Brasso matey, Put it on and let it dry for a bit then give them a good polish
might need to do it a couple of times but does seem to work
Steviewevie
September 19, 2008, 9:41 am
You could also use a clay bar, which should do the job. e.g the [url="http://www.bilthamber.com/autoclay.html"]Bilt-Hamber clay[/url] doesn't need a special lubricant (just water), unlike most other clays.
Cous3
September 19, 2008, 11:12 am
AutoSol is the same, put it on, leave it, then buff off.............does help.
Keith
Paradroid
September 19, 2008, 11:14 am
I noticed this too on my car, it was old wax. I used the Step 1 Paint Cleaner bottle from the 3-stage Meguiars treatment, and that did the trick
roundymoony
September 19, 2008, 11:54 am
thanks guys
will give them ago and let you know how I get.
Chris.S
September 19, 2008, 12:41 pm
a mild finishing compound should do it, such as 3m finesse
WylieCoyote
September 19, 2008, 3:28 pm
Screw up some newspaper and then give it a good rub on the headlight - dry. Brings it up very nicely.
Dan_Harris
September 19, 2008, 5:49 pm
i've got haze on mine too but can't work out if it's on the in or outside of the headlight ?
redz_UK
September 19, 2008, 6:27 pm
i used rubbing compound
roundymoony
September 19, 2008, 8:58 pm
[quote name='Dan_Harris' post='584621' date='Sep 19 2008, 06:49 PM']i've got haze on mine too but can't work out if it's on the in or outside of the headlight ?[/quote]
I'm pretty sure it is on the outside.
thanks very much to all for the help.
VAROOM
September 20, 2008, 1:23 pm
Get the meguires plasticX stuff it brings them up sparkling like glass.
Full Colour Version:
Haze On Head Lights
click here.
