Full Version: Cloudy Yellow Headlights...
Lexus Owners Club > Lexus Models > Lexus IS200 / Lexus IS300 Club
Sang
Does anyone have any remedies for the front head light unit? The plastic seems to have gone dull with age is there anything i can use to clear it back up so that it looks as good as new?
aztecbandit1
I use Brasso on mine mate but you can try T-Cut aswell to try and clean them up a bit with a bit of gentle pressure and a clean cloth on the lenses :)
Sang
What's Brasso? is that the brand or the product name?
aztecbandit1
[quote name='Sang' post='590338' date='Oct 7 2008, 03:07 AM']What's Brasso? is that the brand or the product name?[/quote]
Yes mate, Brasso is a brand of metal cleaner that can be brought at most shops like Asda, tesco etc, But its only a mild cleaner/polish that will remove dirt from the laquer on the light lenses, I used to build headlamps and we used it all the time to remove scratches and marks from the lenses and does work quite well,
T-cut does the same thing as again its only a light abrasive and should remove the discolouring from the headlamps and can be brought from most car shops :)
DimitrisTS
If Brasso does n't work, try wet sanding with 800 - 1200 - 2000 grid sandpaper (maybe the 800 can be skipped if your headlights is not so bad) and then a good rub with some paint finishing compound (i used 3M in a black bottle).
That method worked miracles to me!
Sang
sounds good, thanks guys, i'll give it a try.
spikes
t cut then polish :)
Full Colour Version: Cloudy Yellow Headlights...
