derekyau
October 18, 2008, 10:36 am
[quote name='Huddy' post='593633' date='Oct 16 2008, 12:57 AM']The GS has had a facelift? I didn't know that.
Those parking lines are essential in my opinion. I can't see any reason to discontinue them.
When you select reverse, there should be an icon at each bottom corner of the screen. You can select parallel park or bay parking by pressing the icons, and I think you can toggle the lines on and off. Mine works OK, so if you really can't live without it, I am prepared to swap my 06 for your 08.
[/quote]
Its a slight facelift - most instantly noticeable difference are the signal indicators on the wing mirrors. The front grill is different as well if you look closely enough!
[quote name='alpine' post='593683' date='Oct 16 2008, 10:23 AM']My Oct 08 GS has it. One of the primary, if trivial, reasons I bought the car![/quote]
Mine doesn't either though...
Another thing it doesn't seem to have is the ability to set the distance before the parking sensors kick in. Before, there used to be 2 settings to select.
D.
