Full Version: Lexus Is200
Lexus Owners Club > General Lexus Forums > Lexus Audio/Video/Electronics/Security
mubz
i have a big problem, i had a sound setup i then removed it and then reconnected the system only but the speakers dont work, the stock amp works coz it powers the system! so what else could it be? can anyone help coz i have ran out of solutions, the speakers are connnected properly!
thanks
redz_UK
QUOTE(mubz @ Oct 16 2008, 03:29 PM) *
thanks
bit more info??
Andy-r
Only messin are you sure everythings re-connected properly? did it have seperate amp? like redz says tho more info would help, i'm sure Woza will know whats wrong so try pm'ing him.
The amp doesnt power the system, the system t's off before the amp to power the radio. so it may still be the amp.
mubz
well basically thats it, the system is fine coz its been tried in my mates car, i disconnected it from my car and after a day or two reconnected it but the sound is not coming from the speakers i have turned up the volume, the stock amp is working fine as the system powers up! the speaker wires are connected fine as i had done all the wiring in the car before! i have checked the fuses but cannot be them as in the is200 it only has systems fuse right?? any ideas? thanks
What have you changed the speakers? or are they stock?
Also theres two fuses for the stereo.
mubz
no not changed the speakers, i am using the bypass cable but had used this before when i had the amp and a sub in the car!
So are youputting the standard stereo back in or an aftermarket one?
mubz
aftermarket one and the bypass cable is still being used and was not removed from the car at all!
Is the stereo working ok?
The stock amp has nothing to do with it working if your using the bypass lead, you can take that out completely.
I was under the impression the bypass lead used the stock amp Stav so the standard Fronts & Rears could be used ? ?
Not as far as i know, as you completely remove the speaker connections to the amp and plug them directly to the aftermarket stereo.
No need at all for the amp,
I thought you removed the input lead to the amp from the old OE stereo, and replaced it for the 'bypass lead'.
The Amp to speaker lead remains in place, and the amp does all the impedence matching.
That's my understanding as explained to me by Fargo. The 'Bypass Lead' is in fact mis-named.
Appologies if I am in error.
Well i've not seen one personally myself but looking at the wiring diagram it simply is a long ISO lead, as one of the plug to the amp has power, remote, earth, and the speakers on it so it just connects to them.
that would make sense to me, cause if it did it the way your suggesting you may as well attach to the plugs behind the stereo and use that length of wire rather than removing the plug just to run a lead along the same route.
QUOTE(DJ Wozza @ Oct 17 2008, 08:45 PM) *
Just re-read it and you sound like your describing Fargo's Satnav Lead not the amp bypass lead.
There was a thread a little while ago where Fargo confirmed what I have stated above.. I'll look for it.
EDIT ***** Found it, I wrote this post after talking with Fargo.
You need the stock amp to still be connected to the speakers after fitting the Bypass lead. I would therefore suggest the stock amp stays.
Where is Aztec's thread wacko.gif lol
This one: Clicky
He's on about the Satnav bypass as far as i can understand.
If you have no sat nav,you can remove everything (stereo and amp)
But if you have Sat nav you MUST keep the amp in AND get Fargo's lead for the sat nav to continue working with an aftermarket stereo.
I believe I am correct Stav....
If I'm wrong I'll get me coat..... plus I'll call Fargo some names lmao
Anyone who has a bypass lead postup the instructions ?
As you can see from the picture of the bypass lead its a female plug on it. So you have to put one of the plugs in it, it'd be pointless plugging the signal lead in cause that just runs back to the back of the stereo.
Somebody asked the seller about the resistance when i firstposted about the bypass lead:
QUOTE
HI there
Quite a technical question!!. The lexus we based this lead on never had a digital interface or a sat nav pack.The front door speakers have a passive inductor on the tweeter already in the door. We fed the original bass units in the doors with full range which is fine as quite a few of our aftermarket speaker kits we sell work like this. I have a car audio business over here on the east coast which is how I have made this lead. The rear mid and bass unit again we parallelled up on the wiring at the front as the combined impedence is 3 ohms which again is fine for virtually any decent make of car audio. It's when you get to 2ohms that you push your luck. All the lexus we have worked on, I have always sold upgraded speakers so we have never paid that much attention to the factory fitted speakers which like most vehicles are worth about £1 a piece on the assembly line!!. I have front speakers for £750 a pair!!.
This lead just makes it easy to put an aftermarket stereo in which most people are keen on doing as the lead that plugs in the original lexus machine is a low signal lead and an adaptor I am pretty sure is'nt readily avaliable.I am interested to know a bit about this digital interface as you may know more about this vehicle than I do as I only get involved with the audio/video side. Hope this helps with your enquiry.
Pete
so thats how they get around the impedance, not by using the amp at all.
Steviewevie
From the same thread, heres the lead plugged in to the speaker connections, then straight to the back of the aftermarket stereo. Bypassing the amp completely.
QUOTE(lee_iceman @ Nov 27 2006, 02:29 PM) *
I had the bottom loading unit, it doesn't use the amp at all, you unplug the loom from the amp and plug this lead into the lead you just removed. Then plug the other end into your new stereo.
the part number on the amp should be 86280-530030, although i didn't check mine.
From when Lee_iceman first installed his
Time for me to eat humble pie Stav, I'm big enough (laugh.gif) to admit a mistake huh.gif
That's what I get for listening to others, and looking at Aztec's pretty pictures and not reading the small print in the thread......
What threw me totally was the fact the unused amp was replaced in the pics ohmy.gif
I can of course try (wacko.gif) to claim ignorance as I don't have the Amp (ripped out a long time ago) nor the Bypass Lead smile.gif
redz_UK
having worked on one of these recently im with Stav.
The lead goes from the aftermarket stereo to the LOOM that plugs into the OEM amp. Therefore it bypasses the amp completely and goes straight to the speakers. as above, the impedance on the rears is 3 ohms which 'shouldnt' be an issue on most systems and will infact see slightly more power going to the rears as the resistance is less.
your pic in fact does show this wozza as the lead that is connected is the one that goes into the oem amp removed and connected to the bypass lead
As for sat nav, its a diifener ball game even with the bypass cable, the amp needs to stay in as weel as the oem stereo (or its main board) or fargos bypass unit. If either of these is missing then you will still get power to the nav but the screen will not display anything.
QUOTE(DJ Wozza @ Oct 18 2008, 03:53 AM) *
LOL its ok mate,
You learn something new everyday.
aztecbandit1
laugh.gif i never actually fitted another head unit in the car when i did the walk through, just did it because i was bored one day and i have the factory sat nav, I should of put that you can remove the amp in my topic as i did try it with an aftermarket headunit and the stereo still worked with the amp taken out, Plus its good to see my walk through being used biggrin.gif
Steviewevie
Am I reading this correctly, in that since I am replacing my OEM head unit with an aftermarket head unit, and therefore using the bypass lead (I have a Sport model), and I don't have OEM satnav, I might as well remove the OEM amp because it's not going to be used ?
Steviewevie
QUOTE (DJ Wozza @ Jan 7 2009, 01:54 PM) *
chrisis200
QUOTE (Steviewevie @ Jan 7 2009, 01:57 PM) *
Left mine plugged in as it's far to much hassle to rip it out lol..
yeah 2 bolts lmao
Steviewevie
I was going to use Aztec's walkthrough for plugging in the bypass lead, which involves removing the amp, so I didn't see much point putting it back in unless it was needed ! Another part to add to the spare parts box !
