QUOTE(Steviewevie @ Oct 21 2008, 12:04 PM)
Very easy to fit (2 mins). Makes a very slightly different engine note and slightly helps mpg IMHO. Yes, I think it's recommended to reset the ECU when you fit it to make it start learning about the improved engine breathing. Well worthwhile doing as a mod IMHO.
QUOTE(andy-r @ Oct 21 2008, 12:05 PM)
K&N pannel filter is really easy mod matey just straight swap, not really much advantage performance wise maybe gain 1or2 BHP maybe slightly better MPG does make the engine sound growlier IMHO but the main reason I fitted one is for £36ish they let alot more air into the engine which can only be a good thing. Defo re-set the ECU when done aswell.
Cheers guys, think i'll do it. I remember reading a couple of posts where one said to disconect the battery to re-set the ECU and the other said take some fuses out, any ideas please.
Tommy
