Full Version: Oil Pressure And Rev Counter
Lexus Owners Club > Lexus Models > Lexus Imports > Altezza
MacRS200
Drove the car this morning and I didn't notice anything amiss as the drive is short, lots of junctions and roundabouts etc.
Anyway picked up the car tonight and headed for home as normal, did a glance down like you do and noticed the rev counter was a zero! Did a proper scan and noticed the oil pressure gauge was registering zero as well FFS! Pulled over and cut the engine as fast as possible.
Have a think and come up with: odd that 2 indications gone at the same time. Started the engine and the both came up as normal then dropped back down to zero straight away so I am pretty sure it is an electrical fault rather than no oil pressure. Know the ECU is getting rev reading as the CamCon still shows the revs OK.
Got back home and did an ECU reset (fuses version) and still the same, checked for any obvious fuses on the info I have and nothing that relates to those bits so I am stumped
I am reasonably confident that the oil pressure is OK, problem is that the Tezza has no oil pressure warning light so if I do lose pressure I won't know till the back wheels lock up cry.gif
Anyone got any ideas.
Cheers
Neil
mus26c
any luck with problem mate?
Draltezza
hey, i had a problema just like that, but instated of the rev, was the speed reader, the problems was that the battery off the speedomiter were all most done for so, maybe is the same in ur case
