QUOTE(Lambaj @ Oct 26 2008, 08:39 PM)
Just had to change mine - and managed it without removing anything. Very tight on the hands,and very fiddly to get the bulb holder back in the lamp, but all possible. May be so much easier with the indicator removed..... I'd try it that way now.
Rear lights are easy enough, you just need a deep reach 10mm socket, remove the 4 nuts behind the 20mm diameter plastic caps in the boot trim panel and the whole lamp will pull out with a bit of a wiggle.
Just a word of caution...... dont drop the nuts, they are not standard M6 as you would think with an 10mm spanner, but something a bit smaller. Not standard as far as I can see, so keep all four!
Rear lamps are standard 21W bulbs for the brake and indicator, and a 501 blade 5W for the side lamps.
Cheers
Tony
Hiya Tony/Guys
I did mine by taking off the indicator lens which meant I had more room. It took me about 3 minutes in total so an easy job,
Thanks for the advice everyone....
Glyn
