Full Version: Engine Management Light!?
Lexus Owners Club > Lexus Models > Lexus IS200 / Lexus IS300 / SPORTCROSS > Engine & Transmission
Lisam
Hey all,
I just bought a is200 a couple of weeks ago, nd its an absolute savage car!! The thing is tho last week the engine mgt light came on. Got it reset but a couble days later it woz on again. So i brought it 2 da local toyota garage. Da reader came bk wit da result of a gear cam sensor problem, didnt get da error code. I know i should have! Anyway, I got a quote 4 €1500 2 fix it. They also told me that i might aswell replace da timing belt at €500 even tho it had been replaced a few thousand miles ago! I really dont think either of da above is da problem 2 b honest. Does any1 have ny suggestions?
Plus, da exhaust seems 2 b smokin a fair bit 2, it has been fully serviced nd fairly low miles 4 da year.
please any suggestions? dont no wot 2 do! thanks!!
Rob
your keyboard seems to be missing a few letters mate!!
you need to have the actual fault code - any garage can do that so no need to go to toyota, once you have that come back and people can help a bit more.
if it is the cam sensor code it could be that the sensor has broken. now i may be wrong but i remembe something similar happened to another member a while ago and the cambelt was 1 tooth out.
does the code come on after high rpm???
kam05
QUOTE (Rob @ Nov 3 2008, 12:55 PM) *
That was me. As you've had your timing belt replaced recently, I'd agree with Rob, your timing belt is one tooth out rather than a fault cam sensor, although it is possible.
Smoke in exhaust might be water in the exhaust system (water burning off), you'll notice more this time of the year.
