QUOTE (gall84 @ Nov 5 2008, 11:03 PM)
hi everyone.
i recently,about 2 months ago had new discs and pads fitted all round,ebc discs and green stuff pads on the front.
since having this work done when i corner,a noise comes from the wheels,a scraping noise which sounds like metal on metal,any ideas on what this is and how to cure it
,thanks in advance?
Sounds like your brake disc backing plates are rubbing mate, if you push the plate back away from the disc it usually stops it, but i'd do them 1 at a time and give it a quick test drive after bending them back a little, and if it still does it do another one, On our 2 IS200's it always seemed to be the rear passenger side that did it for some daft reason so i'd try that one 1st? they just need a bit of force on them and if you have the 5 spoke alloys fitted you can do it without taking the wheels off
