Screen remains at showing the same thing even though I can change normally the memorized radio stations.
If I use the manual radio frequency tuner, then it shows the correct information.
If I push any memory button, then its tuned ok but the same frucking sticking readout will come on screen again…!
Only solution is to use the manual tuning and then RE-store the station to the wanted memory button. If I do that then the specific memory slot will operate ok. (well until it happened a second time the same thing after some weeks...)
Does anyone else experienced something similar and what is causing it??
