Full Version: Lexus Is250
Lexus Owners Club > Lexus Models > Lexus IS 250 / Lexus IS 220D / Lexus IS 250C
mubz
would jst like to know what inch wheels the is250 can take without rubbing will 19" be ok? thanks people
Anees
Its all in the offset - as long as the offset is correct you should hopefully be okay.
Mr Mole
QUOTE (Anees @ Nov 9 2008, 08:19 PM) *
And you can always get your arches rolled if needed.
Tango has some very nice 19's on his IS250 I think
Tango
QUOTE (DJ Wozza @ Nov 10 2008, 12:31 AM) *
20" dia. will also fit if you can cope with the thin sidewall. It isn't the diameter (within reason) that determines whether they'll fit or not, but the width and offset.
Here's my 19" offsets and widths with the difference in clearances from the standard fitting.
Wheel Size (diameter and width): 19x8.5 Front - 19x9.5 Rear
Wheel Offset Front:+38..offset extends +13mm to standard/+1mm inner gap
Wheel Offset Rear:+42...offset extends +42mm to standard/-16mm inner gap
its_a_doozy
Nice wheels.
Have you upgraded your break callipers as well? I see they say Lexus on them.
Tango
QUOTE (its_a_doozy @ Nov 10 2008, 05:07 PM) *
Nice wheels.
Read my sig...it's all there, and this is the original post on the calipers http://www.lexusownersclub.co.uk/forum/ind...ic=47048&hl=
its_a_doozy
QUOTE (Tango @ Nov 10 2008, 07:48 PM) *
Nice wheels.
Damn my eyes !! msn-wink.gif Thanks for clearing that up. Its a good look, thinking of doing something similar next year, subject to available funds...
