Full Version: Timing Belt Done Today. Close Call
Lexus Owners Club > Lexus Models > Lexus IS200 / Lexus IS300 / SPORTCROSS > Engine & Transmission
coolrides
had my belt done and water pump done today at 97000 miles and it was very close to no engine left. big chunks missing and threads hanging out. could have been expensive if had of left it any longer. also the water pump had leaked lots of pink gunk in behind the belt cover which was not helping.
if in doubt get it done!!!
did you take a photo of the old versus new belt ?
coolrides
QUOTE (DJ Wozza @ Nov 12 2008, 08:36 PM) *
have the old belt so will get photo of it an get it up someday. near keeked my kacks whan i seen it lol
spikes
QUOTE (coolrides @ Nov 12 2008, 08:39 PM) *
Steviewevie
Sounds like perhaps it was the original belt, and if so perhaps it shows that Lexus were crazy to originally think that a 100K interval was ok ! Will be interested to see the pics.
coolrides
yep few deep sighs of relief lol.
jamesholden
I'm not quite sure but if Toyota/Lexus state the the belt only needs to be replaced every 100k or so many years then if its the original and it snaps within that time frame then Toyota/Belt Manufacturer should be held responsible for suggesting such a replacement interval. Afterall if they said 5 years or 60k then you would have replaced it sooner.
coolrides
must admitt mine is a 99 but i never new if its had a belt but obviously not lol. water pump was prety bad too. def recommend changing it if your doin belt
lexol
Are you changing the idler and tensioner aswel? My mechanic says its not neccesary?!
cheers
Steviewevie
QUOTE (lexol @ Nov 12 2008, 09:33 PM) *
Pretty sure you should be changing those at the same time. I got those changed when my belt was done this week. Might as well, do you really want to have those same used items rubbing against your new belt for another 60K miles ?
coolrides
cheers
they did not look in bad nick but i have been told the tensioners can wear so just put a belt kit with idler and tensioner and water pump. would not like to trust them when i get my nitrous fitted. better safe than sorry
Good move IMO mate, the Tensioner is essential, the Idler a sensible precaution,
as it the Water Pump.
spikes
QUOTE (DJ Wozza @ Nov 12 2008, 10:27 PM) *
