QUOTE (coolrides @ Nov 16 2008, 01:48 AM)
guy that did my timing belt was finishing my car and i watched him fill the radiator but he did not seem to bleed it. are these cars self bleeding or do i need to take action. he said toyotas sort themselves out normally??
levels seem fine and everything seems to work ok and temp is spot on when driving
how is the temp at idle??i work for toyota and the way we normally bleed them is to jack the car up as high as you can at the front untill you get hot air through the heaters then switch off let cool for a bit then top up if req!they can be a bit of a bugger to bleed though!hope that helps?
ps remember their is two places for the coolant to go!!!!
