If you are just doing the pads, then the tutorial I did here ------->
clicky for the front brakes should cover it (the rear setup is pretty much identical other than a single pot caliper on the rear). If you are dong the discs, I haven't done a rear disc tutorial yet and will be different as the rear disc have the park brake drum and shoes incorporated. You might want to check out the "Slide Pin Overhaul" tutorial I did here
clicky just in case you want to do that at the same time.
p.s. Welcome to LOC
