lexusls4302001
Nov 22 2008, 05:19 PM
Hi again!
Ive also noticed that my drivers side window is slow going up and down - and I know its not coz of my weak battery! It does it even if the engine is on. The other windows are fine. Im just wandering if I should spray some WD40 down it to help its lubrication. Does anyone else have any idea what simple checks / tests i can do? Im hoping its not the motor or something expensive!!
Many thanks again for any advice
steveskeggy
Nov 23 2008, 06:40 PM
Mine did that so I used WD40 on it into the runners.
Makes a bit of a mess, but easily cleaned, and it works
Found out my drivers side mirror didnt want to fold in or out either after it had been washed, WD40 came to the rescue again.
keep a can in the car now...
Haylands
Nov 23 2008, 07:16 PM
Hi
Powdered graphite is the correct lubricant to use for windows, you can buy it at good car parts stores, I also think Maplins stock it, it comes in a puffer tube, you puff it onto the window runners and all will become lovely again.....
Pete
click here.
