Just a quickie to ask you all if you know where i put the grease on the new shims/pads. I was sent a little packet of stuff with each set of shims (f&r), and obviously i dont put it on the pad face, do i need to put it all around the shim - between the shim and pad, and the back of the shim???
Another easy job brings up questions - it makes me realise how little i do know....
And is changing the pad sensors yourself an easy job anyone? i didnt look when i had the wheel off........
