Full Version: Acceleration Lag Time
Lexus Owners Club > Lexus Models > Lexus IS200 / Lexus IS300 / SPORTCROSS > Supercharging & Turbo Modifications
alee
Dear All,
I am driving a spercharged Lexus IS200 Manual. The supercharge has been installed over 1 year. Recently, I noted lag time during acceleration. Could anyone advise the possible cause?
Cheers
Slipping belt?
alee
Hi sparkystav,
Possible. When I press the paddle fully, the lag time is obvious. When I press the paddle slowly, it is ok. If the cause is slipping belt, how to fix?
Cheers
You need to tighten the tensioner. Its just below the charger on the cradle. you need to loosen the bolt, then have friend push it so the belt is really tight as you tighten the nut again.
i would also suggest changing the belt for a new one.
alee
QUOTE (sparkystav @ Nov 25 2008, 12:23 AM) *
Thanks Stav,
Just to clarify. Are you referring to the belt driving the supercharger?
Yeah i am.
