I need some help. I suspect that the brake discs I have (3G Brembo) are warped due to vibrations I get at 40mph+ through the steering wheel and brake pedal.
I emailed 3G the following:
QUOTE
Hope you are well.
In April 2008 I bought a full set of 3G 20GR brake discs for my Toyota Aristo V300. These were fitted a few months later due to a lack of time and being busy with other projects at the time. The discs have done no more then 2000 miles because the car is my weekend car and they appear to be warped! I have not driven the car hard at all, usually just pottering about. I am getting vibrations through the brake pedal and steering wheel every time I brake at speeds over 40 - 50 mph. I use the 3G discs (which are basically Brembo disks), with Hawk Brembo Spec Brake Pads which are designed to work with Brembo discs. I am a member of the MKIV Supra club and the combination of Hawk Brembo pads along with 3G Brembo Discs is a tried and trusted method.
I have been to two respected independent garages (both well known to members of Lexus Owners Club) and both come to the same conclusion that the discs are warped! They have checked for worn balljoints and any play in the suspension and have found no issues. I bought 3G discs because of your great reputation amongst car enthusiasts for a quality product.
Your website does state:
We offer a full refund or replacement discs if any major failure i.e. cracking, occurs within one year or 10,000 miles of purchase date. We will also offer a full refund or replacement discs if a problem is apparent immediately after or during fitting.
I would like replacement discs sent since the fault is easily within your terms and conditions. How does the procedure work? I can send you a copy of the original receipt, I also have the current and last years MOT where you will see the car does no more then about 4000 miles in a year. Will you be able to send the discs on an exchange basis so that the car is not off the road while the discs are being changed. I
Thanks for your assistance.
Hope you are well.
They have given me two options.
1. I buy a new set of discs, swap over the old discs and then send them back to be checked. If they are found to be warped I will be given a refund on the purchase price of the new discs. If my old discs are not warped however then they will be cleaned up and sent back to me and the new discs that I have I can't return and have to keep.
OR
2. Take the discs off the car, send them back for checking and they will replace the discs that are found to be warped. I would much prefer this because if the discs are not found to be warped then I'm not out of pocket having bought another set of expensive discs.
Trouble with option two is that don't have anywhere I can leave the car jacked up with no wheels for about a week. I asked my mates with a garage if I could leave it with him and they just don't have the space at the moment but said I can keep the car at some point but will probably be after Christmas/January - I don't want to wait that long! I considered trying to find some Axle stands and maybe leaving the car on the drive, but my drive is on a slight slope and I am uneasy doing that myself.
This is probably a long shot, but I am on the beg/borrow to see if anyone has a set of old discs I could borrow just to get me from the garage and back home.
I need ideally Supra TT front discs and rear Lexus GS300 discs. Car will be drive probably 20 miles max on them and the plan would be to go to the garage, change discs over, send off 3G discs to be checked, drive home on temporary discs and park up until the replacments arrive and then drive back to the garage to have them fitted.
Any help appreciated.
Thanks,
Anees
