QUOTE (Rogue @ Nov 27 2008, 11:08 AM)
Dastek Unichip as supplied by Wallace is a piggyback ECU & here is what (according to Dastek) it does or allows to be done by the tuner:
Variable valve timing adjustment
Rev limit adjustment
Boost limit & level adjustment
Dual maps for use with different fuel grades & types
Water Injection
Nitrous oxide progressive injection
Bigger/supplementary injector handling
Variable induction control
Launch control for turbo vehicles
Full throttle gear changes
Road speed limiter removal
Speedo conversion for imports
Shift light
Idle speed stabilisation
Like Adrian I am not an expert on this but all seems to work very effectively with the s/c on my car.
cheers
Bobby
But no individual injector control unfortuantly.
QUOTE (Steviewevie @ Nov 27 2008, 11:56 AM)
Would it be worth starting a thread with some information on the various types of piggy-back ECU, possibly that could be a sticky ? It's something that's often asked about on here. I'm assuming there isn't an old thread like this already.
I'm thinking of something like the exhaust sticky that we already have, e.g. TTE black box, HKS FCD/VPRO/etc, Greddy, Unichip, etc. Pros and cons of each (e.g. some can control fuel injectors and some can't ?), reliability (bad for TTE black box ?), rough cost, ease of config/mapping, suitability for supercharger/turbo, etc, etc.
The problem is theres too many variables. Some you only need if you have a new engine, some wont handle some types of injectors, some require unlimited extras to work properly. and theres so many types unfortuantly.
A lot as well, the information is held closely by the makers. I.e the HKS FCON V PRO, you have to be a specialist power writter to even see the instruction book/installation diagrams.
If you need any info on the FCD/Black box/Emanage Ultimate or Blue, give me a shout and i'll see if i can help.
But Unichips and FCON V pro's are pretty specialist. Trying to look in the FCON SR at the mo.
Then you've got even more complex ones like the LINK system (i think Memo is using on his V8 install)
I will try and sort some info out later tonight if people want?
