Full Version: Decating The Exhaust
Lexus Owners Club > New Members Area > New Members Area
i5200
Hi there..I m Arman from Bangladesh..I just got a JDM spec Altezza (lexus is200 version with Beams 1G-FE)..despite having a trd light weight main pully n a blitz nur specr exhaust, maa ride is as slow as a boat..few people suggested me that i should go for a decat...i m utterly confused..has ne ne1 out here went for a decat?? If so..den wot iz the result?? Plz i need help, suggestion or anythin regarding this..
Welcome,
I have a decat pipe in mine, just got it custom made by the local Exhaust maker, about £100. But also theres precats in the exhaust manifold that you can take out, but cutting open the manifold and scrapping them out then reelding, or getting an aftermarket manifold.
If you remove the main cat you'll prob need a o2 simulator to stop the warning ecu light coming up cause the final o2 sensor will see the gas un filtered and send an ecu code.
i5200
Thanks a lot for the info...i can take care of the ecu warning thingy...but does it realy help if u take the cat off..meanin any bhp gain at all??
TheDon
mostly if you have any form of forced induction such as a turbo or a supercharger..
I think that with a normaly aspirated engine that you wont see as many gains unless there are further tuning done to the cars engine... will make it sound a bit deeper though..
I had my pre cats cut out completely and a new section of pipework re-welded into place.. made it sound very raspy and fast!
i5200
So...even if i go for a decat...will i be removing the pre-cats or the main big cat...??
To decat you'll need to remove both.
i5200
since there r 2 precats n 1 big cat..wil i have 2 remove all the cats??
If you want to DE-CAT then yes you will.
The clues in the name.
Steviewevie
If you think that the car is currently "as slow as a boat" then I don't think that removing any or all of the cats is going to make any difference to that.
i5200
Thankz guyz..letz see wot i can com up wit..
cameron is200sport
will this not have a problem when going for the mot or do you just put the main cat back in??????
aztecbandit1
QUOTE (cameron is200sport @ Dec 1 2008, 07:35 PM) *
Not sure if he'll have that problem as he's in Dhaka, Bangladesh, whistling.gif It will in the UK though matey smile.gif
Steviewevie
Have a look at this thread for more info (and pics) on Stav's decat pipe.
