legendswraith
December 2, 2008, 6:04 pm
[quote name='WODJ' post='610680' date='Dec 2 2008, 01:41 PM'][quote name='garethr' post='610502' date='Dec 1 2008, 11:23 PM']The noise is the pump which pressurises a nitrogen-filled accumulator with brake fluid.
When you brake the pressure in the accumulator is used up.
Once the pressure drops far enough, the pump runs to re-pressurize the accumulator.
If the buzzing is loud, it may be because the pump's rubber mounts need replacing.
If the pump operates more than once every four or five applications of the brake, the accumulator may need replacing.
[url="http://soarercentral.com/sc-forum/messages/9739/166885.html"]Soarer Central -- Removing/Recharging the TRC Nitrogen Accumulator[/url]
[url="http://soarerworld.com/forum/showthread.php?t=16080"]Soarer World -- TRC Accumulator 1[/url]
[url="http://soarerworld.com/forum/showthread.php?threadid=4953"]Soarer World -- TRC Accumulator 2[/url]
[url="http://planetsoarer.com/UZZ32/REHAB/rehab.htm"]Planet Soarer -- Common problem #9 - Brake discs, fluid bleed, and booster accumulator[/url]
[url="http://planetsoarer.com/mediumbrakes/masterbleed.htm"]Planet Soarer -- Bleeding the TRC master cylinder[/url][/quote]
Thats an excellent reply
Thanks very much.
From reding thru, it sounds like the accumalator knackered then.. As the pump is working nearly constantly without me even touching the brake pedal..
It's just buzzing at 1 second intervals... If i push and hold my foot on the brake pedal it then buzzys constantly for around 8-10 seconds then returns to the 1 second intervals, and i can feel it pulsing thru the brake pedal ...
Does anyone know if he accumalator for a GS300 will fit ?
Cheers
WODJ
[/quote]
If its a turbo aristo no if its a n/a aristo yes its the same. If you have a nitrogen backed system though you must have the TT
